T Offline
Hi all.. Can I use stock 69 Firebird Motor mounts to install a 69 GTO 400 Cubber.. I sure do hope it will fit okay without having to modifiy the motor mounts.. anybody know,??. has anybody done this before.. Thanks... Dale
On A Steel Whore I Ride,,
See the thread on multi-fit engine blocks. Your block should have 2 engine mount holes on each side drilled and tapped. If so, you are good to go.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Yes it will work
It's exactly the same as the Firebird block.... Only difference is the numbers on it.
As stated above...yes...I have a I have a '68 dated, YS coded 400 from a Lemans/GTO in my ;67 Convertible Firebird...bolted in no problem....
4 Offline
Ditto...I have a 68 YZ 400 (68 GTO) and no problem.
T Offline
Whew,, This is good news,, I have already spent a lot of money getting this thing rebuilt,, I was pretty sure it would fit, but I have been fooled before.. Thanks for the info,, I figured if anybody would know you all would.. Thanks again... Dale
JFF 1
