Posts: 399 |
hi guys,pulled up my carpet today and i found a sound underlay underneth.looks like tinfoil on top and tar under.is there a easy way to remove this or is it going to be a royal pain.any help.thanks jim
Posts: 6,341 |
You might actually want to keep that. I used a similar product on the entire floor and firewall (inside) under my carpet. It truly made a huge difference. If that stuff on your car is the product I am thinking of, you could be in for a tough time removing it...
Posts: 9,027 |
I agree keep it on unless you are doing some floor reconstruction of course.....
Posts: 79 |
Anyone know who sells a good replacement material? is it called dynomat etc??
Mike
Posts: 10,338 Likes: 3
Posts: 10,338 Likes: 3 |
Epay, Ames, NPD, almost everyone carrys it.
I think its under 50 bucks for a whole set.
Posts: 79 |
I think its under 50 bucks for a whole set. Cool-Thanks!
Mike
Posts: 399 |
hi guys,thanks for your imput,i did pull 1 peice off so i could get a good look at the floor.very hard to get off so the rest is staying right where they are.thanks jim
Posts: 442 |
Finished my sound deadener today, it is a mess to work with. Hopefully worth the effort.
Keith 68 Bird 428 Auto.
Posts: 13 |
Finished my sound deadener today, it is a mess to work with. Hopefully worth the effort. Look like Fat mat,sound deadener i used in my car.
1967 drop top
Posts: 7,719 |
I got my set from Quiet Ride. Quiet Ride Firebird/Camaro
Posts: 442 |
Posts: 2,175 |
Keep it!
   It's only a hobby... It onl a hob.. it o ob.
Posts: 679 |
Jim,
It is a pain in the butt to remove. After peeling off the foil you're probably going to be stuck with sheets of tar stuck to the floorpan. You'll probably want to use a 1" putty knife and a propane torch. Gently heat the tar and it will slide off pretty well. Don't heat it too much or it'll catch fire and/or gas you out. Good luck.
- Jake
Posts: 2,131 |
how about trying a product called lizard skin? they recently displayed it on horsepower tv and ive heard good results from others on it. they used dynamat on top of it to reduce the icabin noise tremendously but i've heard its a reall sound killer!!
Andy
Posts: 399 |
thanks all for your imput. thanks again jim
Posts298,899
158
