Posts: 7,719 |
This is the sheet metal cover for the TH 400 tranny that provides access to the flywheel and torque converter at the bottom of the bell housing.
Was it bare metal or painted? If painted, what color was it?
Posts: 14,265 |
I believe they were/are black.
Posts: 2,175 |
I need one of these if anyone has one available.
thanks in advance!
JM
   It's only a hobby... It onl a hob.. it o ob.
Posts: 7,719 |
Then I will guess semi-gloss? (As in like Eastwood Underhood Black?)
Posts: 20,054 |
my guess would be they are same color as th350 cover....mine looks semi gloss
Posts: 11,905 |
semi gloss black for the old ones. Later years I've seen engine blue
Posts: 50 |
I am in the market for one of these as well. Thanks
Posts: 3,615 |
Mine is semi gloss black, with Pontiac metalic light blue oversray and engine oil and transmission fluid highlights...with a little road dirt here and there, just for texture.
Posts: 7,719 |
I can picture that. Mine also has numerous small dents I pounded out before I sand blasted it.
Thanks, everyone. I should be pulling the car off the roller skates tomorrow to get it running this weekend and want to knock off all the under car work while I have the nice ground clearance.
207
