Posts: 116 |
Hi Guys, I'm looking at what appears to be an original Sprint 6 convertible 4 speed car. How to I tell if it is genuine? I have the VIN and the body tag.
thanks! dave
1967 original 326 Coupe (my 12 year old son's)
1968 400 Coupe - 467 stroker (mine)
1968 Sprint 6 4-speed convertible
1982 K5 Blazer
2008 GMC CC 2500 Z71 Duramax programmed and piped
2009 Nissan Murano (wife's)
Posts: 14,265 |
If it's a 67 the body trim tag will help. If not, you will need the PHS to be sure. Is the VIN on the engine block?
Posts: 116 |
1982 K5 Blazer
Posts: 14,265 |
If the engine is original it should have a ZD code on it....
Posts: 11,905 |
and the engine has a partial VIN stamp that will match the one on the VIN plate.
Posts: 14,265 |
Look just behind the oil filler tube on the passenger side of engine. Look for the flat pad between the head and block which pertrudes out just enough to see the 1/4" letter/numbers stampings.
Posts: 1,715 |
The partial VIN is stamped along a vertical pad adjacent to the bottom bell housing bolt on the passenger side of the block. The block code is on the block surface adjacent to the head behind the oil filler tube.
Posts: 116 |
Thanks guys. I'll be looking at it tomorrow evening. It's a 1968 'Sprint' Convertible, 4-Speed, power top, standard interior, 120K miles, verdura green, black interior and top, manual drum brakes. I have the VIN and the body tag. So is the ZD on the engine VIN the only way to tell without doing a PHS? Thanks. Dave
1982 K5 Blazer
Posts: 11,905 |
Read the above posts. Having the ZD engine code does not guarantee the engine is original to the car.
Having the block VIN that matches the car VIN, AND has the correct engine code, increases the likelihood.
Posts: 116 |
Thanks again! Would this be a very rare combination? It appears to be in great shape from the pics except for some rust around the rear wheel wells and the trunk lid around the Pontiac letters. the car comes with new quarters and a new trunk lid. he wants $11,000 firm. Sound fair? Thanks again. dave
1982 K5 Blazer
Posts: 11,905 |
I recently bought a comparable 400 4 speed '68 convertible for a couple thou less. Sprints are a lot of fun, but don't command exceptionally strong market pricing at present.
Posts: 3,889 |
$11,000 is on the high end. With the rust you describe I wouldn't go over $8,000. And with economy the way it is, folks are taking a hit trying to sell. So ya may get a deal if he's willin' to.
Posts: 116 |
He came down to $10K. Not sure what to do. I haven't seen anything comperable in that price range locally or on EBAY. I'd rather have one with a V8.....decisions decisions.....
1982 K5 Blazer
Posts: 116 |
OK. I ended up buying the car. Still not certain if it is an original Sprint or not. If it isn't, everything has been added. It has the limited slip rear with 3.55 gears, the correct intake and exhaust manifold, 4 speed, emblems, etc. Everything else matches the body tag as original as well. The engine partial VIN matches the vehicle VIN. The only thing that I can't figure out is the block code. Is the block code on the side of the block between the oil dipstick tube and the transmission bell housing? If so, it appears that it is ND. That doesn't match anything that I can find on the web for codes. It has an 'N' and then a little bump on the block and then a 'D'. The center section of the block has '9790043' stamped on the side. Any ideas guys??? Also, how do I ID what exact 4-speed it has? Thanks again! Dave EDIT..... I was looking next to the dipstick on the block instead of the 'oil filler tube' and up by the head. It is in fact a 'ZD' block. very cool! I'm glad that it is in fact 'numbers matching'! Thanks again! Dave
1982 K5 Blazer
Posts: 45 |
Are you going to post any pictures of the car and more info on it? I had a sprint just like yours back in high school. A nice car....
"It's always funny until someone blows a motor."
Posts: 3,889 |
OK. I ended up buying the car. Still not certain if it is an original Sprint or not. If it isn't, everything has been added. It has the limited slip rear with 3.55 gears, the correct intake and exhaust manifold, 4 speed, emblems, etc. Everything else matches the body tag as original as well. The engine partial VIN matches the vehicle VIN. The only thing that I can't figure out is the block code. Is the block code on the side of the block between the oil dipstick tube and the transmission bell housing? If so, it appears that it is ND. That doesn't match anything that I can find on the web for codes. It has an 'N' and then a little bump on the block and then a 'D'. The center section of the block has '9790043' stamped on the side. Any ideas guys??? Also, how do I ID what exact 4-speed it has? Thanks again! Dave EDIT..... I was looking next to the dipstick on the block instead of the 'oil filler tube' and up by the head. It is in fact a 'ZD' block. very cool! I'm glad that it is in fact 'numbers matching'! Thanks again! Dave Good to hear ya got a little bit off the asking price. Best thing for ya to do now is get the PHS documents for the car. Most Sprints and OHC-6 came with a 3spd manual trans unless ordered with a 4spd. Post some pics!
Posts: 116 |
1982 K5 Blazer
Posts: 116 |
1982 K5 Blazer
Posts: 116 |
1982 K5 Blazer
Posts: 116 |
1982 K5 Blazer
Posts: 3,889 |
Sweet! It's nice to see another L-6 under the hood. You'll find it's an attention getter at car shows, and may see a lot of finger pointing with, "I didn't know Pontiac had a six cylinder."
Posts298,896
1 members (Jimc2002),
129
