#145697 10/10/08 08:24 PM
Looking to cut out the front floor pans on my 67 Bird Conv. Can anyone give me some guidance on who sells the better product as in metal thickness and best quality out there.. I'm just looking to replace both front part only.. Also any advise on how to do this?. Thanks..
Carlos
1967 Coupe 326
1967 Conv.326
[email protected]
I just bought a driver's pan from Shermanparts.com. I don't know if it was a Golden Legion, Goodmark or other brand but the stamping lined up and fit perfectly. I used only a small piece of a partial pan.
Vikki
Restoration Gallery
http://thefirstgensite.com
That's what I'm planning on doing, I may not need the entire pan. I'll check there website.. Any advise on doing this process.. Thanks Vikki...
Carlos
1967 Coupe 326
1967 Conv.326
[email protected]
http://store.shermanparts.com/images/skus/695-40AL.jpg is the part I got.
I had it installed by the body and paint shop. Photo shown below has the patch roughed in, showing how well the ribs match. The drain plug hole is not die cut, so if you want it as original you need to cut it out.
Vikki
Restoration Gallery
Looks like they just cut the floor out a little smaller than the patch and then laid it on top and spot welded it on. Pretty simple. Seal it up and you're done.
Robert
Vikki thanks for the pic..
Carlos
1967 Coupe 326
1967 Conv.326
[email protected]
Posts298,896
0 members (), 140 guests, and 19 robots.
