Posts: 133 |
I need pix of how much of the firewall is exposed near the blower motor. I'm redoing my car. Some wanker modified my car with side air louvers.. smashing in the side firewall area, screwing up the blower motor area bad. I think i'm going to just patch it up and spray it with por 15 because i'm going to go with a vintage air setup. I just need to know how much is visable by the eyes underhood, anyone have pix of that area? thanks
Posts: 133 |
no one has pix? Please Just need pix of that area. Need to know what I have to 'hide' I see no purpose of fixing a cosmetic issue that can't be seen.. help!!
Posts: 639 |
Peter, you can buy a new cowl pocket, there repo'd just finished replacing both of mine.
Posts: 1,770 |
Pete I will go take a photo of my 69. Sit tight.
Posts: 1,770 |
Here you go.
Posts: 1,770 |
By the way, they sell repro sections for that as well.
Posts: 1,770 |
With the fender on.
Posts: 133 |
so, with the fender on, you can't see it at all? I'm not going to replace it for cosmitic issues that will be covered up
Posts: 11,905 |
make sure you can fit the blower motor in the hole, but otherwise you should be okay.
Posts: 133 |
I'm goign with a vintage Air setup.. so hole is going to be welded shut  as long as it can't be seen at all, i'm going to clean it and spray it with por 15 and forget it for ever
Posts: 1,770 |
I noticed you have A/C as well, and it will certainly be all covered up.
Posts: 133 |
[img:center]http://img.photobucket.com/albums/v498/petethewicked/carfront.jpgimg] most of it done, still need to plug that hole
Posts: 2 |
I have installed vintage air in my 68,came with a round cover to plug the blower hole.
hope to salvage the moon buggy someday.
Posts298,895
