Posts: 317 |
I never have liked a gold interior so I am planning to swap it to black and have a couple questions.
Painting the plastic/metal dash pieces, anything special to do to get the paint to stick and look good on these?
Anything overly difficult about stripping the dash trim/accessories off before I paint it?
Can anyone recommend a brand/part number for interior paint?
The carpet is bad anyway, along with the headliner, trim, seat belts, door panels, and seat backs. Figure if I have to change it I might as well like what I change it to.
Posts: 10,337 Likes: 3
Posts: 10,337 Likes: 3 |
The plastic and metal parts should cover with paint just fine after a good cleaning and de-greaser, and possibly a light sanding with wet/dry. Prime and paint. The vinyl parts I would not recommend painting, but you didn't mention that, so I will assume you are replacing with your new color.
I am still needing one set of rear gold seatbelts and buckles, along with other misc. gold trim. So if you are interested in parting with some of your old items, please let me know.
Craig
Posts: 1,015 |
if you go black buy new for some peices. sell the rest. i could use some ivy gold parts for mine. I have a set of black original deluxe. would like ivy gold deluxe.
mark
Posts: 7,719 |
I have always purchased my interior paints from Classic Industries. Therefore, I believe it was them that highly recommended "Plastic Prep" (I think its called) to remove grease and then a brown flexible primer ("Plastic Primer" maybe?) for interior plastic parts. I have always followed that advice and never had a paint adhesion problem.
Posts: 7,719 |
Well a quick review of the latest CI catalog shows that the names are different now. They call them OEM EZ Prep and OEM Adhesion Promoter.
But then I see they a completely new line of interior paints that are supposed to “bond” with soft interior materials and supposedly down need any prep work.
Posts: 1,375 |
Check with Pete. He's just done the same thing.
John
Posts: 3,363 |
SEM brand is about the best for plastic interior parts. The parts need to be cleaned/degreased, dried and then you need to use an adhesion promoter and then very fine light coats of the SEM top coat to achieve the desired results.
So far after 2 years, I've only found one small area where it has chipped or scratched... but at least the color on mine was almost the same underneath, so it's not obvious.
SEM usually can be found at most automotive Paint supply stores or on line and they have the widest variety available.
Brett!
Posts: 317 |
Alright, thanks for the advice guys.
2,110
46
