Posts: 59 |
I have a 67 firebird that has a 400 from a 71 gto in it. It is suppose to have the original carb, intake etc. Does anyone know where I can look up codes? I already looked up motor and heads. need intake, carb,dist. exhuast manifolds. I want to get an idea what this may be worth as I would really like to get the correct wz 400 for my 67 firebird conv. Thanks,Tyson
Posts: 20,054 |
Q, sounds like something for you?
Posts: 2,726 |
Here's the place to find part numbers, casting and stamping codes for almost all Pontiac parts. Save this page to your favorites, you're going to to go there a lot. It works in reverse as well. You can also search by the part number, this will tell you what it came from. http://www.teufert.net/pontiac/page2.htm The block stampings for 1971 400 GTO are YS and WT. Do you also need to know where to look on the parts for the casting or stamping numbers? Q
Posts: 59 |
Hi, thanks guys,info helped. the motor is a ys block. Where is the numbers on the intake? I think I found the rest alright.I had some trouble finding the carb numbers on the sight you pointed me two. it is a 7041540 mf. If you could help on that I would aprecciate it. The dist shows to be from a 1966 tri power 421. #'s 1111054 exhuast manifolds and alt. are from a 68 firebird. Thanks again,Tyson
Posts: 2,726 |
The intake part number is across the top of the #3 runner, in front of the carb. I did not find a good picture of a 1971 intake, P/N 481733, but here's a picture of a 1972 intake: http://images.andale.com/f2/110/118/4817025/1082427614012_485912_1.JPG The 1972 P/N is: 485912, almost legible in that picture. 7041540 is a 1971 Buick 4 barrel, 455, Automatic trans. That's why it didn't appear on any pf the Pontiac pages. Q
Posts: 59 |
Posts: 2,726 |
Posts298,899
158
