Posts: 50 |
I have a repop 400 hood on my '67 bird. I have read conflicting reports about the hood latches. Some have said that you need a '68 hood latch, while others have said that you have to use a '67 latch. Can anyone verify what the correct latch to use is?
Thanks, Mark D.
Posts: 50 |
Okay, I should have used the search function first! I found out that the receiver is different on the hoods - flatter on 67, more angled on 68 & 69. I will have to look at the car tomorrow to see what I have. If the latch does work (opens and closes) properly would it be safe to use even if the latch/receiver is not mated properly?
Thanks again, Mark D.
Posts: 10,338 Likes: 3
Posts: 10,338 Likes: 3 |
I believe all repops are '68-'69 style, not '67.
If you have a '67 assembly, you will need to swap it out for a 8 or 9 assy. (unless a PO already did it)
Posts: 50 |
Well, something finally worked out for me! Looking at the hood today it is indeed a '67 model repop, most likely from D&R from what I have read on the performance years forums. There is a thread on their forums that shows a hood from a '67 and a '68. The '67 receiver has less of an angle than the 68 & 69 hoods. I also made sure and I do have the '67 latch, so everything turned out okay!
Posts: 1,739 |
You can get the repop hoods both ways, but most vendors don't know what they sell. From what I've read, the '67 catch will work with '67-69 latches, but a '68-69 hood catch won't work with a '67 latch unless you do some grinding.
Posts: 825 Likes: 4
Posts: 825 Likes: 4 |
My repop 400 hood for my '69 would not close without some modifying. Thought it was just an adjustment thing.
Posts298,897
122
