Posts: 2,157 |
Thought I would share some pictures of what the inside of a kickdown switch looks like. The switch was stuck and needed cleaning. I also needed to replace the plunger since it appeared mice had chewed it or just pitted badly from use but ended up using Por-15 putty to fill in the pits then sanded it down since I couldn't find a replacement plunger. The bracket in the pic is for a 2bbl and will be replaced with an aftermarket 4bbl bracket through Ames. They also sell the rubber boot to finish the detail. There are 8 indentations on the metal case that hold the plastic piece in on the back. A small blade screwdriver was used to carefully bend them out in order to remove the plastic piece.
Posts: 70 |
Good Stuff!
I need a new plunger for my unit, I swear that I saw someone selling (retail) but now I can't locate. Seems you tried also with no luck.
Thanks for the pics, I'll be after mine soon using this info.
Regards,
![[Linked Image]](http://i570.photobucket.com/albums/ss147/trapperjwg/68%20Firebird%20400%20Convertible/Picture001-1-1.jpg) ![[Linked Image]](http://i570.photobucket.com/albums/ss147/trapperjwg/68%20Firebird%20400%20Convertible/DSCN0650-1.jpg) John Gragg '68 400 Droptop Riverside, CA.
Posts: 7,719 |
I needed a plunger too, so I just installed a Lokar unit instead.
1,616
65
