#189520 02/26/10 08:39 PM
OK with all this horn talk and trying to get them to work. Where would the relay be hiding at?? Thanks as always in advance. Bill
400PLUS #189521 02/26/10 08:41 PM
If original, right under or next to the regulator.
My car hates me...
Oh Oh That leaves me out. Does it have an L shaped plug??? Anyone got a pic?? Im sorry frown
400PLUS #189526 02/26/10 09:04 PM
E
ebd Offline
E Offline
Pic of old 67 400 coupe rad support.
EB
Texas
ebd #189529 02/26/10 09:22 PM
Thanks EB. Yep all thats GONE! But it's all wrapped and wiring stuck under the fender. smile Looks like im looking for a Orange and Black wire??
400PLUS #189548 02/27/10 02:42 AM
Actually that "orange" wire is a very faded version of the original red.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
salmon38 #189583 02/27/10 02:23 PM
I put in a internal regulated alternator and eliminated the regulator. Hear is a pick of mine.
rohrt #189625 02/28/10 07:30 AM
Yes I too no longer have a regulator. I have a GM wiring book. Just doesn't seem rite??? frown I KNEW this wasn't going to be EASY Ha Ha smile
400PLUS #190983 03/16/10 04:54 PM
J Offline
Did you ever get your horns figured out. I'm in the same boat. I think I need a new relay. Before I disconnected my horns they would occaisonally honk out of the blue (usually with the wheel turned hard. I decided to get a new front light harness (already replaced the engine harness) and thought I would try to get the horns to work.
jlwdvm #190984 03/16/10 04:57 PM
D Online: Content
Sounds like you may have a short to ground in the steering column.
J Offline
How would I check that? I do have an aftermarket wood wheel by Grant with their install kit.
jlwdvm #190988 03/16/10 06:07 PM
D Online: Content
There's your answer, you probably have a loose horn connection on that aftermarket button. I'd start there.
