#19958 08/11/04 09:23 PM
Has anyone attempted to rebuild their hydraulic cylinders? I am currently going through my whole power top system and am contemplating what I can rebuild. Any input would be appreciated! Thanks.
I have recently attempted to rebuild the cylinders. They are pressed together when factory assembled. You could probably get them apart but you would have to find a way to press them together so they would hold oil. I rebuild a lot of cylinders but these are beyond me. I checked the repair manuals and they say "replace". I found the best deal around on a new pair($209) and I'm waiting for them now.
Thanks for the input. I thought about cutting them open with a pipe cutter near the crimped end, rebuilding the piston and welding them back together. I do not see a good spot to cut it, where it won't interfere with the stroke of the piston. frown I am going to replace my lines, clean up and reseal my motor/pump assy and bench test it........ Wish me luck!?
Good Luck! I thought my cylinders were in good shape. When I was rebuilding my top frame I ran the top up and down about fifty times to get the frame just right. Both cylinders were working good with just a little bypass when one cylinder locked up. I thought for sure that I could rebuild the cylinders. I got out my trusty repair manual and they said replace not rebuild. Now when I think about how many times that the top will go up and down I'm glad the cylinder locked up and forced me to buy new ones.
Birdsprinter,
I called these guys and they said that they can refurbish the cylinders. I don't remember if it they will save you very much $$$. Here's the site:
http://www.convertibleparts.com/hydrauli.htm
Vince
I replaced my cylinders not too long ago and bought my parts from these guys... http://www.hydroe.com/Parts_Hydraulic.html#TOP
They had better prices than most,had the parts in stock, and shipped quick with no hassles.
Good luck,
Dave
MY BIRD
Let us be thankful for the fools. But for them the rest of us could not succeed.
--Mark Twain
Thanks for all of the replies! I am going to purchase some new lines and bench test my set-up. If I have any problems, I will investigate your leads.
Thanks again,
Rob
Topics35,545
Posts298,893
1 members (69musclecar), 149 guests, and 23 robots.
Geoff 1
