Posts: 12 |
Does anyone have any pictures of where the nozzles are located in the cowl along with the routing of the hoses for the windshield washer system?
Posts: 9,027 |
They point at the windshield  There should be two channels in the sheet metal below the valance with screw holes next to them. On my 68 the hoses go from the passenger nozzle thru the firewall gutter to the pump, and go along the drivers side fender to the reservoir...
Posts: 20,054 |
I have ,for a 69, not sure if location is the same.... here are pics just in case...hard to see but you should be able to see it in the crevises on the drivers side, a shiny piece in slot no 5 from left.. and faintly in the middle of the large opening closer to pass side...
Posts: 20,054 |
Posts: 6,160 Likes: 51
Posts: 6,160 Likes: 51 |
Bjorn has probably posted the pictures you need but note that some 1st Gens had a second left nozzle routing configuration: See: https://firstgenfirebird.org/forums/ubbth...amp;Search=true
Jim '68 400HO Conv.
Posts: 302 |
Here are the nozzles from my 67.
Pete
Topics35,545
Posts298,892
90
