Posts: 1,363 |
There was a guy at work that wanted to test a theory on his relatively new honda. Same idea, never changed the oil or filter. Simply added when it was low. Apparently he went 60K miles before the engine threw a rod. Just goes to show you that the recommendation to change every 3k miles is probably overkill.
Larry 1967 Sprint Convertible
Posts: 1,170 Likes: 1
Posts: 1,170 Likes: 1 |
Wow, just came accross this, Pontiac must have issued different owners manuals sine mine says 5quarts for the 400, with filter change for an AC car.
Posts: 5,108 |
That's strange since all oil pans have the same size sump. Have noticed some show little over/under full mark on oil changes. Just figured was do to how far the lower tube was installed inside the block. Wouldn't worry if little over since probly 2/3rds(?) are up in engine while running...
Posts298,896
114
