#217399 01/15/11 07:24 PM
M Offline
Does anyone know if the 67 Firebird had the 3 pt. seat belt that attached on the rear quarter by the rear window? Also, were the 2 pt. seatbelts retractable in the front?
Thanks
1967 Firebird 400
4 Speed
Convertible
Edelbrock Aluminum Heads, Carburator and Intake
No. '67 had two single 2 pt. seatbelts in the rear seat.
They also had the 1/2 (2 pt.) retractable for each of the front seats. The retractor was outboard of the seats, and the inboard side was a 1/2 length non-retractable.
If you're talking about the shoulder belt, they make an aftermarket, but none came with them originally.
M Offline
Has anyone used the shoulder seat belt? It does not look comfortable but seems to make sense.
1967 Firebird 400
4 Speed
Convertible
It's been talked about before (I think somewhere around 2007/2008?). You'll probably have to do a forum search.
I have the aftermarket shoulder belts. Install was simple and they work good.
I use the original shoulder belt setup. It's a little restrictive but it's supposed to be. Not uncomfortable. Not as convenient as a three point but they work. I pulled them out and for awhile ran some racing harnesses but they gave me a hard time at tech because I didn't have a submarine belt so I went back to the original setup. You should have seen the look on my Mitsu-boy ride-along instructor's face when I showed him how they worked...Priceless
M Offline
Dan, can you tell me where you got the aftermarket ones and which ones you bought?
Thanks
1967 Firebird 400
4 Speed
Convertible
I bought them from Morris Classic Concepts.
http://www.morrisclassicconcepts.com/Billy%20Page%20Three.htm
M Offline
I forgot to mention that my car is a convertible. I am looking for some after market 3 point seat belts for the front seats of my convertible. Does anyone have any suggestions?
Thanks
1967 Firebird 400
4 Speed
Convertible
M Offline
....or does it make a difference that it is a convertible? Do all of the aftermarket 3 point seatbelts work on coupes and convertibles?
Thanks
1967 Firebird 400
4 Speed
Convertible
The upper anchor for convertibles is about two feet farther back than for coupes, behind the cover by the window crank/switch. So you'd need to have enough webbing to accomodate a driver and passenger with the seat full forward. I haven't looked recently, but I could not find one advertised with enough webbing length.
Vikki
Restoration Gallery
http://thefirstgensite.com
K
K Offline
Kurt S
CRG - www.camaros.org
Posts298,849
0 members (), 1,084 guests, and 125 robots.
Geoff 1
