A
A Offline
I've got a friend who says he came across this in a barn in his area (south AL) and I'm wondering how rare is this combination?
This is the first '67 Firebird I've seen with the 8 lug option, he hasn't had a chance to run the PHS to see if it might be a prototype. Even the tires are bias ply, obviously been there for a while.
Any thoughts? Alan B.
N
N Offline
Looks like someone changed out the spinals from a
Grand Prix or maybe the brake drums are interchangable.
I put a Grand Prix console in my bird, not rare just
different and not factory.
Wasnt an option. Someone did a swap.
My car hates me...
It IS April first, ya know.
How rare? We call this "one of none". grin
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
What ever the case, 8 lugs look good on almost any Pontiac.
Hank K.
Green Bay Wis.
E
E Offline
If they were never available on the GTO, they definately never came on a Bird!
A
A Offline
what would be involved with the swap? I realize the big car had 5 on 5 pattern, and the bird has the 5 on 4 3/4 pattern...is it simply a case of bolting the drum on? What about the front spindle?
I'm just learning about Firebirds...
I looked into this a few years ago. You are right about the bolt pattern-so no the drums don't bolt on. Also they are 11x2-1/2 on rear so backing plates don't bolt up. Axles do not interchange and the entire rear is different. In front the spindles will bolt to the bird upper a-arm & ball joint but the lower is different and none of the big car stuff works on the bird. It could be done but would require much fabrication & modification. Pontiac did consider these for GTO and built a prototype but did not produce them. Several years ago there was an article by a guy who did the conversion. The result was great but VERY costly and time consuming.
Brian 67 Bird Convrt. under construction, 67 Tempest 428 Covrt. finished(?)-owned 35 yrs.
1 members (Jimc2002), 101 guests, and 17 robots.
JFF 1
