Posts: 59 |
Here is a list of everything I need. I am needing the parts to be in good shape so if need be I can sand them down and re-paint them or refinish them.
Some metal and other body parts: Rear Brake Drums 400 Hood & Scoops Hood tach Park Lamp Lens (x2) Park Lamp Housing (x2) Upper Cowl Vent Hood Latch Assembly Inner Fenders (x2) Hood Tachometer Antenna
Engine Parts: Starter Water Pump Fuel Pump Crankshaft Pulley
Engine Bay Components: Windshield Washer Motor Windshield Washer Pump Battery Tray Fan Shroud Blower Motor Heater Cover
Other Parts: Instrument Panel Dash Bezel Ignition Switch Bezel Radio plate (burl wood) Fuel Tank Cap
Posts: 31 |
Posts: 7,408 |
I have crank pulley, water pump, fuel pump, battery tray, starter, left inner fender, 400 hood and scoops, hood latch, hood tach, turn signal lenses and housings.
Si Vis Pacem Parabellum
Posts: 2,113 Likes: 1
Posts: 2,113 Likes: 1 |
He mentioned burlwood which would suggest a '68
Posts: 59 |
I have crank pulley, water pump, fuel pump, battery tray, starter, left inner fender, 400 hood and scoops, hood latch, hood tach, turn signal lenses and housings. that is a good chunk of my list! Could you pm me your best prices on each?
Posts: 59 |
He mentioned burlwood which would suggest a '68 that is correct, a '68
Posts: 7,408 |
Check my parts for sale ad
Posts: 59 |
I didn't see it, can you post the link?
Posts: 7,408 |
Posts: 59 |
I have crank pulley, water pump, fuel pump, battery tray, starter, left inner fender, 400 hood and scoops, hood latch, hood tach, turn signal lenses and housings. thanks for the link here is what I am still interested in battery tray water pump main and rod bearings hood latch
Posts: 5,108 |
Have a water pump. Not sure condition. Engine was out of car before i got it. Still need heater housing and motor?
Posts: 3,912 |
I have a couple of upper cowl vents you can have one just pay for s/h
202
