#238270 09/29/11 01:47 PM
M Offline
My engine is finally in the shop and the fellow there is recommending duplicolor. He said he heats up the engine a bit then applies the first coat lightly. Then a series of light coats.
He did however say it's been a while since he painted a Pontiac blue.
So I am just wondering if the Duplicolor paint available is correct looking.
If not what is?
I saved a link a while back on this subject but lost it. Looking at history I can't find it on topic.
Please advise.....Thanks...
Yes, Duplicolor DE-1616.
But I had better results with Plasti-kote 227.
68tpls400 #238281 09/29/11 02:49 PM
I had good results with the paint from Ames.
Mike
Hoody #238282 09/29/11 03:06 PM
I used the Duplicolor, I was happy with the results. OReillys had it to me the next day.
Larry
1967 Sprint Convertible
68tpls400 #238283 09/29/11 03:08 PM
You can get Dupli-Color primer, paint and clear coat for the engine.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
Gus68 #238290 09/29/11 04:05 PM
S Offline
I used por-15 high temp silver as a primer on bare block then used engine paint from The Parts Place. Afterwards when still tacky I sprayed with hightemp clear,that was 4 years ago and still looks like the day it was sprayed .
smokediver #238323 09/29/11 09:03 PM
supposedly the best paint come from Bill Hirsch.
http://www.hirschauto.com/
thios is the one....its in brush on , you can also get it in spray... http://www.hirschauto.com/prodinfo.asp?number=EE-QUART&variation=PON%20M%20BL%20E
P
P Offline
I picked-up some Dupli-color #1610 that say's Pontiac Blue on the can,is this going to be the "wrong" color blue for my 67???
Thanks, Phil.
phil40 #240090 11/01/11 12:59 AM
A
A Offline
i was wondering how the paint has held up on the heads of your engines?
Allen
allen neal #240119 11/01/11 04:10 PM
Take a look at http://www.pontiacpower.org/enginecolor.htm
1610 appears to be correct for 1959-1965. For your '67 you want Dupli-Color #1616 or its equivalent in another brand.
Pete
allen neal #240124 11/01/11 05:58 PM
heads hold up fine, not exhaust ports...
