#240767 11/12/11 06:03 PM
well i got rid of my rodchester for now and using a holly. i could never get the thing to run right. i love this holly. the reason im here is that the car idles well now but when i open it up i noticed a slight pop through the secondaries of the carb. could it be the size of the carb or not adjusted correctly? timing? its a spead bore without external float adjustments. the heads are rebuilt but could is it possibly a valve problem? that was why i asked for push rod sizes. i was thinking that the rods are too long and that the valve was not closing correctly. if that was the case what would be a good clue to check for? any suggestions will be greatly appreciated.
mark
I had the same problem...... Cured it by adjusting the timing
Had the exact same problem when running manifold vacuum advance. Switched to ported and problem solved!!!
thank you, ill look into it.
mark
1 members (Rus), 985 guests, and 131 robots.
