Can anyone help me? On my 68 FB the gen and oil light come on when I start the car. Then the oil light will go off and the gen light dims when the car warms up. I have replaced and tested the voltage regulator and alternator. Any thing that I am missing in this?
Thanks
Check your battery voltage and then check the voltage at every connection point between the battery and gen light, ie - the connection point on the rad support in front of the battery, horn relay, voltage regulator, firewall harness plug, instrument gauge plug. Some where along the way there is a bad connection, still working but needing a cleanup. I have also seen bad voltage regulators right out of the box.
Gerry
T Offline
Quick look at the condition of your battery cables would be in order, also. Corrosion inside the cables will cause poor connection of circuit.
Steve wink
N
N Offline
Sounds like a main line power problem, something is inhibiting the voltage that gets to the two idiot lights. Gotta work your way through each piece, as the boys have stated.
Posts298,896
