Posts: 15 |
I have a turbo 400 automatic transmission. When I am in the top gear is the transmission suppose to kick down into passing gear when I floor the pedal? Could this be a vacuum problem or something not connected? Any help would be appreciated. Thanks
Posts: 2,263 |
On a TH400 the kickdown is actuated with an electrical switch which is mounted on the carb.
Posts: 15 |
Someone told that it was an electrical switch but didnt know where it was. I will check the carb. The previous owner put a new 4 barrel on the engine so maybe he didnt hook it up. Thanks TOHCan for the tip. What would I be looking for on the carb? Is it typically located in the front or back of the carb? Thanks again
Posts: 7,719 |
This will be a black switch mounted to a bracket on the driver's side of the carb with a plunger jutting out from the front of it that the throttle lever hits as it approaches WOT (wide open throttle).
It will have 2 wires to it.
Posts: 6,758 |
Colorado68's pic shows it best:
Posts: 15 |
Awesome, Thanks a lot for the help. I checked this earlier and dont remember seeing this on my carb. It is a new 4 barrel that was purchased through summit. There are no other marks on it but the words Summit. I will check this in the morning. Thanks again.
Posts: 7,719 |
If you do not have the OEM one, which is not reproduced and really difficult to locate used, Lokar makes an excellent replacement that utilizes a cable, works great with aftermarket carbs, and it really easy to install.
1,607
119
