Posts: 8 |
I have a rearend out of a 67 firebird sprint. not sure on the code...it is the original rearend 3:23 posi , new brakes- hardware, wheel cylinder..powder coated...(I can't find the code due to the powder coating)...any info would be greatly appreciated...seen wide price range from high dollar 700,800 to 150.00 thanks henry
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Not sure about the value, but that should be a pretty desirable item. Does it have the "ears" on the pumpkin and the traction bar brackets on the axle tubes?
Posts: 8 |
it has the ears and tracion bar mounts...I have someone interested in it but he is just looking for a rearend w/posi for a camaro...the rearend is all original....except the powder coating. i will post a picture when i can
Posts: 1,459 |
Being 1967 makes it unique somewhat, 68-9 used an upgraded rear suspension eliminating the need for the traction bar(s).
3.23 rear would be the last of the 2 pinion posi units, 3.36 & up got the nodular case and the 4 pinion posi, and better axles as well.
My .02 would be in it's current condition all fresh, $700 would be fair. If you have a nodular it could be worth 1K+ for the right ratios.
Steve
It'd be sad seeing it go into a crapmaro. As Steve said, it's a unique piece and 67 firebird only (for correctness). Some needy 67 bird owner might be glad to have it. Usually the crapmaro guys want 12 bolt chevy units.
169
