#248005 03/10/12 05:21 AM
Like me, the old Firebird seems to sagging in the rear a little more and more the last year or so. With funds being a little tight I'm considering either replacing the leaf springs or using a set of helper springs. The ride is fine, just need to gain back about an inch of tire clearance. Has anyone used a set of helper springs that worked or would that just be a waste of money?
-=>Lee<=-
You can go the 70s high school kid route and use shackles.
Bob S. #248009 03/10/12 01:06 PM
I used air shocks no shackles.
Restoring a 1968 400 4spd, numbers matching Firebird Coupe, Verdoro Green.
Larry
My old 68. Wish I had her back.
3 Offline
New springs is the right thing to do.
I would just wait and save and keep saving so you can do it right the first time.
Why put x amount of money into air bags,helper springs or whatever just to end up replacing the springs eventually anyways ?
"New springs is the right thing to do.
Why put x amount of money into air bags,helper springs or whatever just to end up replacing the springs eventually anyways ?"
There ya go...
D Online: Content
The shock mounts are not strong enough to hold all the weight of the car via air shocks...save for springs.
Bob S. #248023 03/10/12 04:36 PM
LOL, I resemble that remark, 'cept I used airshocks with shackles back then.
New springs don't cost a whole lot more that a set of air shocks or helper springs anyway.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
S Offline
Helper springs will work, but you'll be able to see them from behind. Not sure if that's something that would bother you or not.
Air shocks work. They were an accessory option on all Pontiacs. They don't require additional strengthening of the shock plates or upper mounting points. They have a rougher ride than regular shocks.
Because I change wheels often, going from same-size Rally II's to a set of redlines with Rally II's, and also a set of slicks with smaller pizza cutter tires up front, I run air shocks so I can keep the car level.
New springs are the way to go. But because of the one-size-fits-all replacement springs out there, you run the risk of getting springs that will have your car sitting 3 inches too high in back. frown
But yes, new springs are the ultimate solution. Getting the correct ride height (and stance) is the tough part. smile
1964-1979 Pontiac Window Sticker Reproductions : http://www.musclecarfilms.com/PontiacWindowSticker.html
Mike Noun's Pontiac Articles : http://www.musclecarfilms.com/Mike_Noun_Articles.html
1969 Pontiac Invoice Breakdown : http://MusclecarFilms.com/Pontiac_Invoice.html
I've done the air shocks and shackle thing in the past. Don't think shackles would even fit behind the valance panel, and air shocks, well, I might as well just use a steel pipe. grin (Had them on my Challenger and hated them.)
But, as was mentioned, getting the right springs with the correct ride height is also an issue, as well as the cost. I've found the Detroit Eaton springs for about $300 with shipping, and the helper springs look be be around $60 to $75. So a big difference in price (as well as installation time.) Really didn't want to replace springs if I didn't have to.
(But considering the cost of gas, I may be spending more time working on the car than driving it!)
-=>Lee<=-
I got a set of springs from an E-bay seller in IL last spring (had a broken leaf on one of the originals) for $125.00 . Guess I got lucky because the ride height is right on.
Only problem is that the new springs were made in china. I didn't realize that until I had them. I like to buy "made in USA" when I can.
Hank K.
Green Bay Wis.
Hank350 #248164 03/13/12 10:05 PM
Yea, think I have several "made in China" parts on my car already. frown I know I can get new springs locally for less money but I'm concerned about getting the ride height where I want it. I could get them re-curved but that's a lot of work to install them multiple times.
-=>Lee<=-
You might consider getting them re-arched. Did it on an old pickup, worked great and wasn't that expensive. Best news is you keep it original.
Larry
1967 Sprint Convertible
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
