S Offline
This car is available for viewing in the Chicago western suburbs.
This is a complete and numbers matching car with a 400 c.i. engine rated at 330 HP, 10.75:1 compression ratio, 4 barrel carb ( code YT ) and Turbo Hydra-Matic 400 transmission ( code PX )
Only modifications are that it has headers, a new Holley carb, Flowmaster dual exhaust and aftermarket wheels.
The car is fast and in good running condition, as it has been serviced to drive away now and restore later.
Front of car looks solid in the doors, fenders, "A" post and rockers.
Belly pan has some rust.
It has had quarter panels installed previously.
Rust areas at base of rear window on down through the area above rear axle.)
Call Tom @ 630-816-6182 or respond to this ad. Pics can be seen at the Craigslist link below
http://chicago.craigslist.org/wcl/cto/2965871742.html
Tom , looks like you`ve posted the wrong part of Craigslist ad...its the "manage" portion, which doesnt show up as we arent logged in...pls change to the real ad.
try this:
availingfaith should be all over this one. smile
maybe he is not interested in 69s_ but it should be a good one otherwise
S Offline
Sorry about that. The link 68tpls400 gave is correct. I have it here too and will edit the orig post for accuracy
A
A Offline
try this:
Hearts set on a 68'. Not big on Cordova tops.
Topics35,545
Posts298,893
1 members (69musclecar), 149 guests, and 23 robots.
Geoff 1
