J Offline
So I'm putting my water pump back together I noticed the waterneck had damage so I bought a new one. The thing is the angle is 90o as opposed to the one that pretty much come straight out of the block.
They look like this:
http://www.amazon.com/Mr-Gasket-2667-O-R...8424&sr=1-1
As opposed to this:
http://www.amazon.com/Four-Seasons-84843-Water-Outlet/dp/B000C2Q99M/ref=pd_rhf_ee_p_t_3
Do you guys just cut the upper radiator hose to fit or should I just buy another water neck.
You want the one that comes straight up at a slight angle, like the four seasons one. The original hose that came with your engine has a bend to it that will fit properly, the one you bought, I believe is for a chevy engine
hope this helps..............Mark
[Linked Image]
J Offline
I did order the right upper rad hose, but I ended up cutting the bend out to get it to fit. Nothing like destroying a nice new hose. I guess I'll order the right combo here to avoid any future problems. Thanks for the input.
I also installed an aftermarket chrome water nexk. I also had to "customize" my upper radiator hose to make it fit after I took the OEM one into the auto parts place for them to compare it to. I just made sure I recorded the number of the hose that they found that worked.
This is sometimes why they call it "hot rodding". wink
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Posts298,899
