Posts: 23 |
Anyone need cocktail shakers for their vert? Cocktail shakers for vertsFrom the ad: "this a set of front and rear, left and right shakers, all in good shape with no leaks and will clean up well, there is some lite pitting (pitting is mainly on rears mounting brackets) but will clean up . they will fit 67 and 68 camaro and firebirds,"
Posts: 6,158 Likes: 51
Posts: 6,158 Likes: 51 |
'67 and '68 Camaro and Firebird vibration dampeners are not all the same. Would have to study them a bit to see what they might fit of those four cars but they will not fit all four.
Jim '68 400HO Conv.
Posts: 23 |
Can you point out the differences?
Jim '68 400HO Conv.
Posts: 23 |
Great link above.
Here is good info if anyone is interested in these:
The following is copied off a forum message on the web.
Here’s some part numbers from the Pontiac Parts book: 67 RH Frt 9789448 Dampener and bracket 67 LH Frt 9789449 Dampener and bracket 67 RH Rr 3909928 Dampener and bracket 67 LH Rr 3909927 Dampener and bracket
68 RH Frt 9792469 Dampener and bracket 68 LH Frt 9792470 Dampener and bracket 68 RH Rr 9792319 Dampener and bracket 68 LH Rr 9792320 Dampener and bracket
69 RH Frt 9797614 Dampener and bracket 69 LH Frt 9797615 Dampener and bracket 69 RH Rr 9796673 Dampener and bracket 69 LH Rr 3962787 Dampener and bracket
1 members (airram),
1,462
111
