Hey guys, I am going forward on the gutting of the remainder of my A/C parts. Since it is not functional and I would like access to the spark plugs on the passenger side, it's time to remove the box. Any suggestions for accessing the bolts that are tucked up on the extreme left? Should I block off the heater hoses while I'm at it?
I know that removing the fender makes it easier to get the evap box off for sure. Others have had luck removing just the inner fender well to get at the bolts around the fan side of the box. Major PITA. Even worse than header bolts.
