#260503 11/21/12 06:22 PM
I bought a 68 with rally2s on it but the wheel nuts are 9 spline nuts and need a female 9 spline socket to get them off. Are these sockets still available ? Local wheel shops haven't seen them before and can't help.
T-Rex #260504 11/21/12 06:44 PM
I had one of those on one of my wheels, and luckily a standard socket fit over it and was strong enough to get it off. I don't know about getting all 5 of them off though. Ugh!
68tpls400 #260505 11/21/12 08:16 PM
C
C Offline
Summit and other retailers sell spline lug nuts and sockets. Here are some of their offerings...not sure how to determine proper size...maybe with a caliper? Also I'm seeing 6 spline, 8 spline....but not 9 spline...
http://www.summitracing.com/search?keyword=spline%20lug%20socket&dds=1
Otherwise, I wonder if a universal socket with the collapsible pins maybe work?
Kinda like these?
http://www.amazon.com/Gator-Grip-ETC-125...niversal+socket
http://www.ebay.com/itm/New-Gator-Grip-E...=item2c69f484ee
I can't speak for quality...never used one and don't own one. But it popped into my head as an alternative...
Do you plan to re-use these? If no, another alternative is to just weld another nut to the top of each one and get 'em off...20 times could get a little old though...a socket that fits would be better...
Or, I'd probably try to just tackle 'em with vice grips...they look long enough to grab to crack loose...
crazecars #260506 11/21/12 08:41 PM
C
C Offline
And...this dude always cracks me up. But he's realistic, and he gets things done. Again...do you need to do this 20 times? You decide if it's a worthy method....
http://www.youtube.com/watch?v=mJUUyjJqk5A
crazecars #260517 11/21/12 11:05 PM
Just find a socket that fits snuggly on the lugnut and just drive it on with a BFH. Use an impact socket if you can to avoid breakage.
Firebob #260572 11/24/12 03:07 PM
If that dont work they do sell a socket that is like a stud extractor that grips good enough to get them off.
bigchief #260587 11/25/12 01:45 PM
I tried jamming a socket on and the extractors and they didn't work ... What I did find was, cementing 3 small dowels into three corners of a 15/16 hex socket takes them off ... But the glue gives way after each nut and I have to re-glue the dowels back again ... At least they're coming off and I guess I've got all winter.
Thanks everyone, for the suggestions
