I just took the engine,tranny and rearend out of the bird. Good news is they all are correct numbers with the exception of the carb and intake. I have a intake with a casting number 3784234 and I believe it should be 9794234. Seems like the last 4 numbers match? any chance it's correct?
I can't find whats it's supposed to fit so I do have hope.
Thanks
Gordy
1968 Firebird 400 4 Speed
68FB400
Hi Gordy.
My Firebird parts manual shows the 9794234 as the correct intake manifold for '68. I believe the casting numbers are the part numbers also. Is there any chance you could be missreading the 3 and the 8 and they could actually be 9s?
Just a thought. Good luck.
John
Pretty sure it's correct, Is there a place to post photos?
68FB400
W Offline
You will have to post the photos to a photo sharing site like Photobucket and then embed as an image in a post here.
68FB400
J Offline
Waiiace racing gives 9790140 for 68 and 9794234 for 681/2
Same on Pontiac power.net
Jerry Tallman
69 455/4sp Windward Blue, deluxe parchment bench seat, under major restoration
je_tallman@yahoo.com
What is the date code? It should be something like G028 (G = July) 2, 1968. It is right by the thermostat base on the water crossover.
It doesn't look like they made any other intakes that end in 4234 other than the 9794234. So if it dates June (F) 1968 or later it must be a 9794234. It is a very good flowing intake that has tested to be as good or better than the after market ones according to Jim Hand's book.
See http://www.wallaceracing.com/intakedata.htm I believe they carried them into 1969 but this chart doesn't show it.
Dion
I have already sent the motor into a friends shop for rebuild. I will have him check both the date and casting number again.
Thanks To all,
Anyone haver a 7028265 carb laying around? I'm sure this will be costing me plenty.
I may be running the 7028244 from a 350 Buick,
68FB400
J Offline
I have a 68 and 69 and believe both are the 4234 I will check to confirm
Just checked, march 68 is 9794234 sept. 69 is 9799068 making it a 1970 intake
Jerry Tallman
68 and 69 400 4bbls both used the 4234 intake. Here is a link to the casting/part number on one of mine for comparison.
http://www.flickr.com/photos/ksnuclear/8356331196/sizes/k/in/photostream/
John
Just to add to this, early '68 400 4BBL intakes were the 9790140. Here is a picture with the casting number and the date code of October 23 1967 on my original 400 engine. As you can see, one picture was taken before the engine was painted. Not sure what date they switched to the 4234 intake.
Dave
Dave
Photos of my 1968 Firebird 400 Convertible restoration (and other cars I own) are in the link below.
http://www.pinballmadness.net/collections/main.php?g2_itemId=3080
1 members (Rus), 985 guests, and 131 robots.
