A
A Offline
I have an issue with the convertible top at the pillar posts.With the top latched down i have a gap between the front header weatherstrip and the a pillar weatherstrip,no matter how much i adjust the latches the gap is still there.Is there any adjustments to the top that can be made to close the gap? Any suggestions would be greatly appreciated.More info,new weatherstripping on top,doors,header,A pillars,new window felts,new top. The gaps are about a 1/4 inch on both sides.Causes annoying wind noise. Thanks Allen
Allen
post up a picture if you can.
Sounds like the same issue I have. I replaced all the weather stripping and I think the issue is with the replacement metro weather stripping and not the top frame adjustement.
A
A Offline
Here is a couple of pics of what i am talking about. The weatherstripping is from Steel Rubber Products,suppose to be one of the best companies.Thanks for any help. Allen Soory not the best pics.
Allen
