#269562 05/17/13 06:49 PM
L
L Offline
I AM HAVING A HARD TIME REMOVING THE CYLINDERS. 68 FIREBIRD. THE PIVOT BOLT/BRACKET IS THE PROBLEM. THE HOLE IN THE STEEL REAR RAIL OF THE FOLDING TOP FRAME DOESNT QUITE LINE UP WITH THE BOLT TOWARDS THE INTERIOR OF THE CAR SO I CANNOT GET A SOCKET OR AN OPEN END WRENCH ON IT. ANY INSIGHT?
Did you try it with the top folded all the way back? That is was I had to do.
Trying to get it on or off?
Make sure cylinder collapsed. I had to disconnect the frame.
Look like your problem?
Take one or both of these bolts and then you can get it out.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
L
L Offline
I GOT THE BOLT OUT OF THE INTERIOR SIDE BUT I AM HAVING A HARD TIME NOW GETTING THE BOLT OUT OF THE PIVOT PART OF THE CYYLINDER THAT IS ON THE OUTSIDE OF THE CYLINDER. I AM HAVING TROUBLE EVEN GETTING A WRENCH TO WHERE THE BOLT IS
