I
I Offline
Can I sand blast, prime, and paint my engine pulleys? They are a little rusty. Any recommendations?
Hope so!!1 I did mine!
Powder coat is also an option
86 Pontiac 2+2
FYI: If you are interested in some under hood bling - R.A.R.E sells billet aluminum pulleys for Pontiacs.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
Do you have a link??? Tried looking it up but could not find
86 Pontiac 2+2
+1 on R.A.R.E....I was slingin belts off when I was doing some 1/4 mile runs...put their billet pulleys on have not thrown belt since, that is with 6K+ rpm.
U
U Offline
6k plus?? What kind of set up you have in your car? Were you using stock pulleys or something else?
4 Offline
I also sand blasted and etch primed my pulleys and they turned out great.
I
I Offline
What color is the black on the stock pulleys (satin, gloss, flat, etc)?
4 Offline
I used SEM satin black etch primer. Not sure if correct or if it should be gloss?
Was using stock pulleys. Current setup is -
1969 YA block - .060 over
10.2:1 compression
Stock crank
Speed Pro L2262F pistons
CAT H-beam rods
Harland Sharp 1.65 rockers
Edelbrock RPM intake
Holley DP 815 cfm
Summit 140 gph electric fuel pump
Edelbrock 72cc heads ported 295-305 cfm
MSD 6AL CD, MSD Blaster 2 Ignition Coil
12 bolt 4.10 posi
200-4R
Art Carr 10” 3200 stall
2" MadDog Headers
DMH Electric cutouts
Topics35,545
Posts298,893
1 members (69musclecar), 149 guests, and 23 robots.
Geoff 1
