been a while since i posted. well, ive been working on my wiring lately. i have a problem that stumps me and thought some one might have some insight on this. the problem is when i pull my parking lights on, the turn siginal lights up on the drivers side for a few seconds along with the front light and then flashes abruptly first then slow down to the normal parking light position then will flash on occasion or stay bright for a few seconds. when this is going on, the rear light is not flashing or shows any problems just the front dr side. i disconnected the rear harness same thing happens. i disconnect the flashers and still the same thing . i disconnect the steering column same thing happens. also the dash plug so i pulled the harness out and traced all wires for a short and fixed some bad connections reinstall and the same thing is going on. im out of ideas. any body have anything or suggestions i can start following.
Recheck all of your grounds connections. Especially the one for the instrument panel (upper center bezel screw for '67)
Seriously. I'v resolved 3 0r 4 issues by "repairing" grounding points. The bezel ground mentioned above is a "strap" that grounds to the dash when the instrument panel is installed.
thanks ill will definately check the bulbs and the grounds through out the car. i was thinking that something is powering up and discharging when i pull the switch. is there anything like that on the ride like the alternator diode that could do that?
