#282856 01/14/14 03:31 PM
howdy what is the best way to remove spot welded pans to break spot wells thanks ron --are real newbee lost in mexico have a good one ron
ronaldjberg #282859 01/14/14 03:47 PM
Have not done that myself, but the recommendation I have seen is to 1st drill out the spot welds with a spot weld cutter.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
ronaldjberg #282870 01/14/14 06:03 PM
right on never heard of a spot weld cutter , but i am about to check it out if you find any thing let me know , thank you ron
ronaldjberg #282871 01/14/14 06:18 PM
there you go harbour freight spot weld cutter thanks much
ronaldjberg #282872 01/14/14 06:24 PM
Use a center punch first and then drill very slowly. A air chisel with a long flat blade helps if the entire spot weld did not get drilled out.
ronaldjberg #282878 01/15/14 12:02 AM
thanks much---what about the rear frame , why dont i see it on npd or fire bird central for parts , i see its welded to the floor pan --just about finished with the rottiserie, that will help to look at things , and also have ordered the books thanks ron
ronaldjberg #282879 01/15/14 12:05 AM
howdy gus 68 what part of alberta are you in , will be there may 1 or so adios ron
