Posts: 12 |
howdy what is the best way to remove spot welded pans to break spot wells thanks ron --are real newbee lost in mexico have a good one ron
Posts: 7,719 |
Have not done that myself, but the recommendation I have seen is to 1st drill out the spot welds with a spot weld cutter.
Posts: 12 |
right on never heard of a spot weld cutter , but i am about to check it out if you find any thing let me know , thank you ron
Posts: 12 |
there you go harbour freight spot weld cutter thanks much
Posts: 1,394 Likes: 2
Posts: 1,394 Likes: 2 |
Use a center punch first and then drill very slowly. A air chisel with a long flat blade helps if the entire spot weld did not get drilled out.
Posts: 12 |
thanks much---what about the rear frame , why dont i see it on npd or fire bird central for parts , i see its welded to the floor pan --just about finished with the rottiserie, that will help to look at things , and also have ordered the books thanks ron
Posts: 12 |
howdy gus 68 what part of alberta are you in , will be there may 1 or so adios ron
2 members (Geoff, Jimc2002),
469
119
