Posts: 365 |
Hi. Can anyone give me info on the ignition switch on my 69 bird. I suspect it may be the reason my car will not start. How do I take it apart. Is it repairable. I put a meter on the coil and it is not getting power when I turn the key to run. No starter when I turn to start. When I turn to acc. I have power to radio so that works. Thanks, Pete
Posts: 20,054 |
is your column cover turned all the way to the left? Do you have the linkeage?or is it removed for headers?
I had that problem...even after getting the ign. switch worked on ,still had some problems...wired an "extra" starting wire from starter to engine room , for a 'hidden in plain sight' extra starting wire...( but ign key must be in and turned on..)
Posts: 365 |
I have a 4 speed I don't think I have the column switch but I will go check it now. How hard is it to work on and what is a good place to trouble shoot it from. Thank you, Pete
Posts: 182 |
Hey Pete...do you have a test light?? I would start at the ign switch and see if you have power coming right out of the switch to the ign and starter wire and track it from there. I cant remember the colors off hand but if you need em I can look em up for ya....or I'm sure someone here knows off hand.
Dave
MY BIRD Let us be thankful for the fools. But for them the rest of us could not succeed. --Mark Twain
2,110
46
