I'm trying to check my timing, but cannot see the timing mark. The HB is clean nor gunked up paint. I would think I could easily see the mark. Does anyone have a picture of this mark? My engine is a 68 Sprint.
I haven't done this in years. Vacuum is disconnected and the light is hooked to the#1 plug. The engine runs very well. That mark should be plainly visible.
I'm just a tad frustrated and stumped.
68 Sprint
Chevy 350 with 4-speed
S Offline
your balancer may have slipped putting the mark way out of range
a mark is cut into both pulley groove shoulders and should be very viable against the timing belt lower cover
Sometimes it is very hard to see the notch especially if the light is weak. Have you tried using a white crayon or piece of chalk to assist. It will get you close and then you can use the actual notch to pull it in.
Larry
1967 Sprint Convertible
Thanks guys. I was able to find a picture. I then kept bumping the starter and finally found the marks. I then marked them with chalk. My timing was a ways out of whack. It's as it should be now and the engine runs noticeably better.
68 Sprint
I took a toothpick and filled the timing mark with gloss white paint. Very easy to see and permanent.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
0 members (), 167 guests, and 26 robots.
JFF 1
