Hi all, we just fired the engine on my '67 resto project tonight for the FIRST time! Yikes! You never know how things will go, right? Overall, it went pretty well (still recovering from the monoxide lol)... She fired right up thanks to my patented carb priming technique (lol)....But now I'm praying that the awesome FirstGen crowd can shave a bunch of time off of my 4 issues, because let's face it, we've all had the same problems over and over, right? Please feel free to check out my pics, and jump in if you have any input on any of the issues!
1. BROWN GOO!!! There is a TON of brown goo in the water system. It seems to have the consistency of whipped cream, only a cardboard color! Kinda smells similar to a machine shop/engine shop (my buddy says this)- if that makes sense- chemically smelling. We bought the motor half assembled, and did go through it, so I know it was not paper, or anything stuffed in motor as we went through it pretty solidly. Seemed very good and was all fresh machining. Has anyone experienced this stuff? Oil on dipstick is clean, the goo is not in motor oil so far. Oil is perfect, thank god. Can the goo be flushed?
2. Voltage issue- When engine runs, battery holds solid at 12.2v when probed directly on terminals. Running or not, 12.2v either way. The battery is clearly not charging. However, the fuse box taps (male accessory terminals, etc) all show anywhere from 12 to 16 volts depending on RPM, and the intensity of the light bulbs in the car also verify this increase. Therefore, the alternator is clearly making voltage, but it's not actually reaching the battery itself. So I took the voltage reg out of my other 67 and swapped- same problem exactly- it didn't fix it. I should note, that I spent a ton of time on all the wiring harnesses, checking each carefully and re-taping completely. The harnesses on my car were not chopped up in any way, so you have to trust me that all wires are accounted for, and in nice shape. I guess I'm trying to say they are all in very good condition, and everything on the car down to the glove box light works with the exception of this charging issue. Could it be a fusible link be blown at the reg? For some reason, the alternator voltage is just not hitting the battery, and there seems to be too much voltage at high RPM at the fuse box! Argh.... Hmm....
3. Tranny is dead. By dead I mean there is no attempt to shift into gear when engine running. i suspect the pump, because I did verify that the pan had 3.5 qts in it when I started. There was no change on the stick- so clearly the converter is not hydraulically locking up, or filling up. Pump? Yes there is a filter, and yes the o-ring is intact, etc.
4. Repro hood tach is no joy- the light works at least, all wires correctly applied- negative coil, ignition 12v, and chassis ground. Any ideas? Could it be I'm using an MSD blaster (round) style coil, and not an actual factory coil? All 3 wires connected per manual.... I think- what little manual it came with- a torn piece of paper!
Thank you so much for helping any way you can. BTW, what is the best way to get pics up here? Dropbox? I'll just link to them below so you can get a feel for where my car is at..
Thanks,
Mike
[img] https://www.dropbox.com/s/2sf4zvy0ocaqah8/2014-05-22%2022.15.02.jpg [/image]
[img] https://www.dropbox.com/s/cp3onigv373d8ck/2014-05-16%2021.55.23.jpg [/img]
[img] https://www.dropbox.com/s/p9cvz15mzwa2jrf/2014-05-22%2022.17.57.jpg [/image]
[img] https://www.dropbox.com/s/us5v2mw2klpnvjl/2014-04-21%2019.54.39.jpg [/image]
Take out the thermostat, tee in a garden hose at the heater hose, start it up then open the rad drain [censored]. let the water flush through the engine for a while. If that doesn't get it out put a jar of coolant wash in , run it for a while and then flush it out with the garden hose again.
Sounds like your Alt is working but you left out the battery charge wire. there should be a wire going from your Alt to the battery, usually from the buss junction at or near the horn relay to a block on the rad support in front of the battery. Try running a wire from where ever you have your junction to the positive post of the battery. The permanent install should have a fusible link in it to protect the battery.
Sorry 'don't know anything about automatics.
I wired a hood tach for a friend and it did not work. Wired it the way someone on this site suggested [forget who] and it worked great. I'll try to find the post and get back.
Are you using an MSD ignition box? There is a connection on it specifically for a tach.
Tranny:
1) when you installed the convertor, did it engage the "ears" on the tranny shaft? I ruined my pump and convertor because I did not install correctly.
2) is your linkage connected properly?
3) did you add at least a quart of fluid to the convertor prior to install?
A
A Offline
>BROWN GOO!!! There is a TON of brown goo in the water system.<
Bruce sings "Hey kid, you think that's oil? That aint oil; that's blood."
I hate to tell you this but it may be oil, and I hope I'm wrong and it's assorted crud
A
A Offline
Pictures.
Switch to full screen, type your blurb, select file manager just below the text box. 5 pictures less than 2m in size
1 members (Jimc2002), 101 guests, and 17 robots.
JFF 1
