#289685 06/23/14 01:07 AM
I got the R59 battery installed and cleaning up the engine compartment for the big car show June 28.
I have a question, there is a little sticker on top that states to "replace with another energizer R59"
Was that sticker originally on it or does it need to come off? You can barely see it under the brace beside the big tag.
HaroldB #290066 07/04/14 03:14 AM
I think it proberbly was on any brand new Delco battery..
-Claus
http://rides.hotrod.com/ride/1003826/clausdanger/1968/pontiac/firebird/index.html
it's NOT black.. it's Dark metallic green.. ;-)
4 Offline
Harold, not sure about your question but I have the "danger" tag on the positive post, only because that's the post it came on from restoration batteries. Do you know which post was correct? Looks better on yours as it is not upside down but I left it the way it was shipped to me.
Tom
1968 400 convertible-wife's summer car
2009 G8 GT supercharged
1991 Toyota MR2-lot's of boost (my dark side needs rice)
[Linked Image from i1011.photobucket.com]
HaroldB #290333 07/12/14 03:28 PM
Okay, this is a whole new level of restoration Geekieness... I just put in one of these batteries on my vert and I was curious about the tag placement, so I just went through a few pictures on some very high-end restorations from some respected people.
Harold, the "Recomend Replacement with Energizer R59" sticker is absolutely correct. All the restorations had this: Gary Riley's restoration of the 1969 Midnight Green Ram Air IV 4spd convertible, The $125k - 69 TA from Mecum Chicago from last year, and Dave Armstrong's 69 Midnight Green 1000 point national award winning "nuts -on" coupe.
455redbird - I like the way Harold has it, because you can read "R59" on the top of the battery, and my battery just came with the tag on the negative pole. However, when I started looking for pictures of this, I found Dave put it on the positive pole, the Trans Am did not have it on, and Gary's restoration had the positive lead disconnedcted in my pictures from the MCACN show, so I am assuming it was on the positive terminal. By the way, on Dave's car it is face up, so you have to read it from the side of the car.
I hope this helps,
Ken
