#290443 07/16/14 10:56 PM
Hey all,
Found these in a box and was wondering if it was a complete side marker housing for one side? Or What?
One part says guide 25 and the other says guide 23
one for each side
Jeff, do you know which one goes on which side? Does it matter? They seem to be slightly different in size.
side doesn't matter, but i see what you mean as far as the part difference. they were used in other cars other than the 68' birds...maybe from two different cars??? maybe just a manufacturing difference...or just an original and a repro???
The Guide 25 one is the same as what is in my 68.
original 1968 Nordic blue 350 coupe
https://picasaweb.google.com/101966588157297835672/Firebird?noredirect=1
[Linked Image]
1987 Dodge W-150 Power Ram
2019 Taco TRD pro
Could the guide 23 be from a GTO or a full size Pontiac?
Si Vis Pacem Parabellum
1968 Alpine Blue 400 4 speed
The GTO and LeMans rear lights are more curved than the 'birds. When set side by side, the additional curvature is obvious. They will fit the 'bird openings, but not seal well due to the tighter radius of the quarter sheet metal. I'm not sure about the part numbers though.
