Posts: 3,220 |
Few items I am looking to clear out. Shipping will need to be added. 4 spd Transmission Xmembers -50.00 under dash Heater box - 50 Original Radiator support gussets-50.00 New V8 motor mounts-20.00 Used V8 motor mounts-10 Dash vents- 25 New Body mount nut and cage - 10 original black Kick panels - 70 (one has a crack on the upper trim) Battery tray- 10 68 front park lights assembly - 30 new repo 67 heater hose support 10 new repo 67 valve cover wire retainer 10 new repo 67 valve cover wire clips 5 original 67 convertible header molding-100 convertible rubber weather stripping for the side rails -20 - SOLD Original 2 bbl f2 throttle cable bracket and cable -30 New ram clutch pilot bushing - 5 New Holley Carb Model 4165 - 250 11 bolt timing cover - 30 old trunk and engine wiring harnesses for any sockets you may need New repop inner window felt fuzzies for the convert door panels. - 30 New one piece solid antennae whip some say used for FM cars. Ball on top. - 10.00 Valley Pan- 50 Convertible tack strip ends-10 original molded door jamb edging parchment - 10 gm door sticker -1.00 driver side rear quarter window molding - 30
Lots of original bolts - body, engine
Posts: 1,923 |
Hey Harold, You got a pic of that thermostat housing? I'll PM you my e-mail. Lee
Posts: 3,220 |
Posts: 3,220 |
Added some pictures of some parts for sell. If you see something, ask and make offer.
Posts: 3,220 |
Posts: 5 |
Harold:
I would like to buy the 400 grilles. Are the grilles 67 or 68? Is there any damage to them? How much for shipping to PA 19446 zip?
Posts: 5 |
Harold:
I would like to buy the Firebird 400 grilles. Any issues or damage? Are they 67 or 68 Firebird? Let me know what you want for shipping. PA zip: 19446
Thanks,
Gray
Posts: 3,220 |
The 400 grills sold last night. Sorry.
Posts: 35 |
how much for the trunk/tailight harness to 76133?
Posts: 3,220 |
how much for the trunk/tailight harness to 76133? How's 30 shipped That harness is good, wiring is not hard and all connectors are there. Someone tapped into the backup wire near firewall connector.
Posts: 5 |
That's okay. Thanks again.
Posts: 1,015 |
I'll take the body bolts. Everything you got. Estimate the weight and shipping to 75033.
Marc Contact me by email.
Posts: 7 |
Do you have bolts to mount the carb to the manifold?
Posts: 3,220 |
Do you have bolts to mount the carb to the manifold? No. I don't have those.
Posts: 3,220 |
Make me an offer if you see something.
Posts: 3,220 |
Still have a few items I am looking to clear out. Shipping will need to be added. Make me an offer. 4 spd Transmission Xmembers -50.00 under dash Heater box - 50 Used V8 motor mounts-10 Dash vents- 25 New Body mount nut and cage - 10 original black Kick panels - 70 (one has a crack on the upper trim) Battery tray- 10 68 front park lights assembly - 30 new repo 67 heater hose support 10 new repo 67 valve cover wire retainer 10 new repo 67 valve cover wire clips 5 original 67 convertible header molding-100 Original 2 bbl f2 throttle cable bracket and cable -30 New ram clutch pilot bushing - 5 New Holley Carb Model 4165 - 250 70 + 11 bolt timing cover - 30 old trunk and engine wiring harnesses for any sockets you may need - make offer New re-pop inner window felt fuzzies for the convert door panels. - 30 New one piece solid antennae whip some say used for FM cars. Ball on top. - 10.00 Valley Pan- make offer Convertible tack strip ends- make offer
gm door stickers -1.00 driver side rear quarter window molding - make offer
Still have some original bolts, if you need a special bolt I may have it.
1 members (Geoff),
2,339
111
