Few items I am looking to clear out. Shipping will need to be added. 4 spd Transmission Xmembers -50.00 under dash Heater box - 50 Original Radiator support gussets-50.00 New V8 motor mounts-20.00 Used V8 motor mounts-10 Dash vents- 25 New Body mount nut and cage - 10 original black Kick panels - 70 (one has a crack on the upper trim) Battery tray- 10 68 front park lights assembly - 30 new repo 67 heater hose support 10 new repo 67 valve cover wire retainer 10 new repo 67 valve cover wire clips 5 original 67 convertible header molding-100 convertible rubber weather stripping for the side rails -20 - SOLD Original 2 bbl f2 throttle cable bracket and cable -30 New ram clutch pilot bushing - 5 New Holley Carb Model 4165 - 250 11 bolt timing cover - 30 old trunk and engine wiring harnesses for any sockets you may need New repop inner window felt fuzzies for the convert door panels. - 30 New one piece solid antennae whip some say used for FM cars. Ball on top. - 10.00 Valley Pan- 50 Convertible tack strip ends-10 original molded door jamb edging parchment - 10 gm door sticker -1.00 driver side rear quarter window molding - 30
Still have a few items I am looking to clear out. Shipping will need to be added. Make me an offer. 4 spd Transmission Xmembers -50.00 under dash Heater box - 50 Used V8 motor mounts-10 Dash vents- 25 New Body mount nut and cage - 10 original black Kick panels - 70 (one has a crack on the upper trim) Battery tray- 10 68 front park lights assembly - 30 new repo 67 heater hose support 10 new repo 67 valve cover wire retainer 10 new repo 67 valve cover wire clips 5 original 67 convertible header molding-100 Original 2 bbl f2 throttle cable bracket and cable -30 New ram clutch pilot bushing - 5 New Holley Carb Model 4165 - 250 70 + 11 bolt timing cover - 30 old trunk and engine wiring harnesses for any sockets you may need - make offer New re-pop inner window felt fuzzies for the convert door panels. - 30 New one piece solid antennae whip some say used for FM cars. Ball on top. - 10.00 Valley Pan- make offer Convertible tack strip ends- make offer
gm door stickers -1.00 driver side rear quarter window molding - make offer
Still have some original bolts, if you need a special bolt I may have it.
