#292829 10/08/14 11:01 AM
Few items I am looking to clear out. Shipping will need to be added.
4 spd Transmission Xmembers -50.00
under dash Heater box - 50
Original Radiator support gussets-50.00
New V8 motor mounts-20.00
Used V8 motor mounts-10
Dash vents- 25
New Body mount nut and cage - 10
original black Kick panels - 70 (one has a crack on the upper trim)
Battery tray- 10
68 front park lights assembly - 30
new repo 67 heater hose support 10
new repo 67 valve cover wire retainer 10
new repo 67 valve cover wire clips 5
original 67 convertible header molding-100
convertible rubber weather stripping for the side rails -20 - SOLD
Original 2 bbl f2 throttle cable bracket and cable -30
New ram clutch pilot bushing - 5
New Holley Carb Model 4165 - 250
11 bolt timing cover - 30
old trunk and engine wiring harnesses for any sockets you may need
New repop inner window felt fuzzies for the convert door panels. - 30
New one piece solid antennae whip some say used for FM cars. Ball on top. - 10.00
Valley Pan- 50
Convertible tack strip ends-10
original molded door jamb edging parchment - 10
gm door sticker -1.00
driver side rear quarter window molding - 30
Lots of original bolts - body, engine
Hey Harold, You got a pic of that thermostat housing?
I'll PM you my e-mail.
Lee
-=>Lee<=-
I emailed the pic.
Added some pictures of some parts for sell. If you see something, ask and make offer.
More items
P
P Offline
Harold:
I would like to buy the 400 grilles. Are the grilles 67 or 68? Is there any damage to them? How much for shipping to PA 19446 zip?
P
P Offline
Harold:
I would like to buy the Firebird 400 grilles. Any issues or damage? Are they 67 or 68 Firebird? Let me know what you want for shipping. PA zip: 19446
Thanks,
Gray
The 400 grills sold last night. Sorry.
how much for the trunk/tailight harness to 76133?
How's 30 shipped
That harness is good, wiring is not hard and all connectors are there.
Someone tapped into the backup wire near firewall connector.
P
P Offline
That's okay. Thanks again.
I'll take the body bolts. Everything you got. Estimate the weight and shipping to 75033.
Marc
Contact me by email.
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
T Offline
Do you have bolts to mount the carb to the manifold?
No. I don't have those.
Make me an offer if you see something.
Still have a few items I am looking to clear out. Shipping will need to be added. Make me an offer.
Dash vents- 25
Battery tray- 10
70 + 11 bolt timing cover - 30
old trunk and engine wiring harnesses for any sockets you may need - make offer
New re-pop inner window felt fuzzies for the convert door panels. - 30
Valley Pan- make offer
Convertible tack strip ends- make offer
gm door stickers -1.00
driver side rear quarter window molding - make offer
Still have some original bolts, if you need a special bolt I may have it.
