C
C Offline
My car is almost ready for paint but the painter has had some issues finding the color by the original codes (Coronado Gold). Now, take it with a grain of salt, he was going through a local parts store and they normally can find OEM colors but said they couldn't find anything on the Coronado Color (I gave them the sheet with all the codes, Dupont, Ditzler, PPG, ect).
Is there some other place that would carry this color, or, a way to mix it from a base? He mentioned using the color scanner but I thought those were approximations.
My body shop had the same hard time finding Coronado a few yers back. Im sure I could get the mix code for you next week if you still need it.
It came out beautiful. I have pictures under my signature if you want to look.
C
C Offline
Ya, if you could I'd appreciate it. Your cars look great by the way.
B Online: Content
You need the paint shop mix up a test batch and do a test on top of the primer base you are using. I had a paint shop mix up Aegean blue from the gm paint code and it wasn't close to what I have seen. I have actually seen 3 Aegean blue birds and all 3 were a different shade. Paint matching is also difficult to do on a color that sun fades over the years.
C
C Offline
Used this link to find all of the model years that used this paint, and got hold of someone that knew the paint system, and they were able to find it.
If anyone needs it:
http://www.paintref.com/cgi-bin/colorcod...Coronado%20Gold
Not sure what brand paint you are planning to use. I went with Dupont Chromabase. I ended up calling Dupont for a code as my paint shop couldn't find a cross reference from the old formula numbers to the new numbers. Anyway, Dupont gave me YM029 as a Chromabase code for Coronado Gold. It looks great on my car. Not sure it's 100% correct, but I haven't seen an original Coronado Gold car to compare it to and there was no original paint left on my car when I got it.
I thought I had some old paint to use as a sample but could not find it.
Posts298,894
JFF 1
