Hey Everybody, Have an oil pan leak, (See previous thread). Bottom line is the pan is sitting on the crossmember and pan leaking oil. If I take the pan off to replace the gasket and then shim the motor mounts to get itup off the crossmember, how do I know when it has been shimmed too much? Thanks!
