Hey Everybody,
Have an oil pan leak, (See previous thread). Bottom line is the pan is sitting on the crossmember and pan leaking oil. If I take the pan off to replace the gasket and then shim the motor mounts to get itup off the crossmember, how do I know when it has been shimmed too much? Thanks!
As long as you get the pan off the cross member and can get the bolts in the mounts I would call it good and not worry.
0 members (), 256 guests, and 22 robots.
