Posts: 3,220 |
I just picked up the correct blue throttle return spring.
For the people that use the correct blue spring, did you add a spring on the inside for safety? I currently have a double return spring that I'm using. It looks like there was only one spring originally.
It looks like if I add one it will take away from the originality look I was looking for.
Posts: 6,161 Likes: 51
Posts: 6,161 Likes: 51 |
I strive for originality but violate it for safety sake. I've probably used a second spring for 30 years or more. It is not within the original spring but pulls the lever forward from another location.
I had a cruise control stick at 70 mph on a vehicle once. Fortunately I was able to stay at the speed until I got to an exit off the Interstate and shut the key off and coasted to a stop for a side-of the road disconnect of the cruise linkage.
Jim '68 400HO Conv.
Posts: 7,719 |
I just picked up the correct blue throttle return spring. Where?
Posts: 3,220 |
I just picked up the correct blue throttle return spring. Where? From Ames Performance
Posts: 2,405 Likes: 1
Posts: 2,405 Likes: 1 |
A second spring pulling forward has an advantage other than safety. The return spring pulling rearward only puts pressure on the carburetor throttle shaft and shaft bore or bushing, which may result in wear of the shaft and or bushing on one side. Having a second spring pulling forward may help alleviate shaft/bushing wear.
Just my opinion, I'm not an expert.
Posts298,896
114
