Premier Member
Premier Member
Posts: 1,179 |
Swapping car over to a stick, anyone have a pilot bearing number that's good I can order from Napa or where ever? Thanks, Ron
Posts: 3,220 |
I used C-0649-1 from npd.
fYI- Make sure your crank is drilled for pilot bearing.
Posts: 4,248 Likes: 14
Posts: 4,248 Likes: 14 |
Don't let them try to pawn off a chevy pilot bearing. They are totally different. http://i32.photobucket.com/albums/d9/strugar/PICT3534.jpgLeft chebby, right poncho
Posts: 9 |
Just bought a pilot bearing for my '68 Firebird. Got it at O'Reilly auto parts. National Bearing 7109. Cost was $22.99.
Dan
Premier Member
Premier Member
Posts: 1,179 |
Thanks guys I will measure crank to see if it is able to accept one..
Every crank I've ever seen is drilled, auto or not.
Posts: 3,220 |
Someone told me that somewhere around 72-74 and up cranks from a auto were not drilled. I don't know cause I've only seen a 70 auto and it was drilled. I have heard people starting a swap and invested in parts and then found out the crank was not drilled for it.
2,192
74
