Premier Member
Premier Member
M Offline
Swapping auto out and going manual, Looking for a 69 clutch and brake pedal and bolt. Give me a shout if you have them. Ron 201-317-0699
69 RA III T/A Auto
69 Sprint vert 3speed ( sold to a new home)
69 350 coupe ( new home in Denver)
69 350 HO 4spd
N
N Offline
I bought mine from Classic. See if you can get a used set with the bracket that they attach to (the steering column, dash, to firewall master cylinder support thingy). The manual pedals mount differently. I converted mine over but having a friend with a lathe to make the tube that the bushings slide into was helpful, Then just some drilling and welding. Good luck, Neill
68 ohc convertible
68 400 coupe
69 350 coupe(455 4 speed)
When I did the swap I used a set of used pedals and they bolted right in to the existing bracket. There was no need for any other parts except for the new bushings to tighten things up.
Hank K.
Green Bay Wis.
Premier Member
Premier Member
M Offline
If you use pontiac ones they bolt right in , the camaro pin type needs some work to make fit, the pin is diameter is larger and the pin is longer, yeah i have to make bushings that come on the camaro carrier and make the carrier hole larger... I have the pin type now but I really would like to find pontiac bolt on type..
69 RA III T/A Auto
69 350 HO 4spd
One other thing to remember is that 68 is different from 69. You would think they would be the same but hey are not.
Premier Member
Premier Member
M Offline
That I know !!! lol
69 RA III T/A Auto
69 350 HO 4spd
Good. You would not be the first to buy a 68 setup and then wonder why it wouldn't work.
Premier Member
Premier Member
M Offline
Still looking for pedals and bolt for a 69 only...
69 RA III T/A Auto
69 350 HO 4spd
Anyone have a pic? I probably have a set. Or two.....
