Premier Member
Premier Member
Posts: 1,179 |
Swapping auto out and going manual, Looking for a 69 clutch and brake pedal and bolt. Give me a shout if you have them. Ron 201-317-0699
Posts: 521 |
I bought mine from Classic. See if you can get a used set with the bracket that they attach to (the steering column, dash, to firewall master cylinder support thingy). The manual pedals mount differently. I converted mine over but having a friend with a lathe to make the tube that the bushings slide into was helpful, Then just some drilling and welding. Good luck, Neill
Posts: 825 Likes: 4
Posts: 825 Likes: 4 |
When I did the swap I used a set of used pedals and they bolted right in to the existing bracket. There was no need for any other parts except for the new bushings to tighten things up.
Premier Member
Premier Member
Posts: 1,179 |
If you use pontiac ones they bolt right in , the camaro pin type needs some work to make fit, the pin is diameter is larger and the pin is longer, yeah i have to make bushings that come on the camaro carrier and make the carrier hole larger... I have the pin type now but I really would like to find pontiac bolt on type..
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
One other thing to remember is that 68 is different from 69. You would think they would be the same but hey are not.
Premier Member
Premier Member
Posts: 1,179 |
Good. You would not be the first to buy a 68 setup and then wonder why it wouldn't work.
Premier Member
Premier Member
Posts: 1,179 |
Still looking for pedals and bolt for a 69 only...
Posts: 67 |
Anyone have a pic? I probably have a set. Or two.....
Posts298,899
158
